Старый 02.04.2026, 15:12   #1
25,751 / 851 (80) +++++++
patrickmouwen: D365 Commerce CSU V47/9.57 Unofficial Release Notes
Источник: https://patrickmouwen.com/technicald...v9-57-10-0-47/
If you work with D365 Commerce — as an architect, developer, ISV, or integration specialist — you know the feeling. A new version drops, the official docs give you the feature headlines, and then you’re left figuring out the rest: what actually changed in the code and APIs? Which schemas gained new fields? What are those new flight keys doing? Where is the product really heading?
That’s exactly why I started publishing these unofficial Commerce CSU release notes.
Every release, I pull apart the Commerce Scale Unit: decompile the assemblies, diff the OpenAPI specs, trace the new code paths, and map it all to what Microsoft shared about the Release. The goal is simple — give the community the technical depth that doesn’t exist anywhere else.
I’ve been building on Commerce CSU since around 2015. Over 650 APIs, B2C and B2B, headless and POS — this platform is deep, and it deserves documentation that matches.
This edition — V9.57 / 10.0.47 — is the most architecturally significant release I’ve analyzed. Here’s what’s inside.
patrickmouwen: D365 F&O/Commerce interfacing via Azure API Management: My Best Practices Blog bot DAX Blogs 0 10.03.2022 02:47
Sumit Potbhare: Retail Warehousing | Wrap up | Approach to D365 for Commerce with Adv WH Mgmt Blog bot DAX Blogs 0 28.04.2021 13:12
patrickmouwen: How to Unlock Many Hidden D365 Retail Features! Blog bot DAX Blogs 0 13.05.2020 22:13
patrickmouwen: D365 Retail APIs Part III: How to use the Retail APIs from Power Automate (Flow) and Logic App Blog bot DAX Blogs 0 28.01.2020 02:15
patrickmouwen: D365 Retail APIs Part II: How to know exactly what happens inside D365 Retail Blog bot DAX Blogs 0 14.12.2019 01:17
Часовой пояс GMT +3, время: 21:56.
