Старый 05.11.2004, 11:55   #18
ZVV is offline
ZVV
MCITP
Oracle
1,006 / 246 (0) ++++++
Из документации:
Remember that all instances in a cluster share 3 things in the cluster environment. This is the Microsoft Axapta 3.0 application files, the MS SQL 2000 database and, if necessary, the port number on a given firewall.
ax3.0, cluster, configuration utility, load balancing, кластер
daxis: Troubleshooting blocked SPIDS in AOS Blog bot DAX Blogs 0 01.04.2009 18:05
Arijit Basu: AX 4 AOS Basics: [Level 100] Blog bot DAX Blogs 0 18.11.2007 14:30
DynamicsTech: What's New in Dynamics Ax 4.0 AOS? Blog bot DAX Blogs 0 12.04.2007 11:50
axaptapedia: Control AOS from command line Blog bot DAX Blogs 0 09.03.2007 14:50
AOS в кластере и слой USP NAST DAX: Администрирование 0 17.02.2006 13:37
Часовой пояс GMT +3, время: 20:02.
