Старый 27.06.2019, 11:47   #12
Logger is offline
Logger
3,990 / 3283 (117) ++++++++++
Записей в блоге: 2
Из документации к 3-ке :
Value ‘0’ for indexes not supported, or
one or more of the other options
added together:
0 : Not supporting indexes.
1 : Default flag for enabling index
support.
2 : Index generation reversed (i.e.
most important index generated last).
4 : Allow DESC on index components
in CREATE INDEX statement.
8 : Add table qualifiers to index
Axapta System Variables Page 13-7
names.
16: Put the DATAAREAID (the
“company field) last in indexes, and do
not put the field in the ORDER BY
clause at all.
32: This session is using “RECIDs per
company”, which consequently will
add the DATAAREAID to the built-in
RecId-index.
64: This session is using “RECIDs per
company+table”
ax 2012 r3, dataarea, index, partition, sqlsystemvariables
axStart: delete an AX 2012 R2 or R3 partition Blog bot DAX Blogs 0 14.04.2015 15:11
Kashperuk Ivan: Tip: Connecting the Warehouse management device portal to a different company or partition in Dynamics AX Blog bot DAX Blogs 0 03.12.2014 19:11
atinkerersnotebook: Copy Data From One Partition To Another Using The Data Import Export Blog bot DAX Blogs 0 03.04.2014 15:11
Подсчет записей в ax2012 с учетом DataArea и Partition. Как лучше? mazzy DAX: Администрирование 0 20.05.2013 18:02
axaptacorner: Data partition in Ax 2012 R2 Blog bot DAX Blogs 0 21.01.2013 21:11
Часовой пояс GMT +3, время: 11:08.
