Старый 22.06.2018, 19:12   #1
kurthatlevik: MSDYN365FO: Automate repetitive tasks – the easy way
Источник: https://kurthatlevik.com/2018/06/22/...-the-easy-way/
Here the other day, I got the task of posting a few thousand Retail Kit orders / BOM-Journals because they failed at the first time. I started, and managed to manually post 50 journals before my fingers got cramps and I started to feel dizzy. I could not multiselect the journals and post them, so I had to manually click “post” on each journal.
I surely sent a SR to Microsoft explaining that this should be easier in standard, and that SR is in process. But it will probably end up as a “As-Designed” state, or “post it to ideas.microsoft.com”.
But there is an easier low-tech way to solving this. Just install a Mouse-ghost app, and it will repeat the task for you. So I used the app “Mouse Recorder Premium” to post all the 1300 journals, and it went smoothly. Just record the clicks and then repeat for a 1000 times.
To make sure I did not “lock” my PC while this was performing, I started the task in a Hyper-V VM, and then it can run in the background.
That’s today’s small trick to get rid of repetitive tasks
kurthatlevik: A Practical Guide for Dynamics 365 Iterative Implementation Blog bot DAX Blogs 0 15.09.2017 01:21
kurthatlevik: New Microsoft Dynamics AX – A guide for using retail sales prices and discounts Blog bot DAX Blogs 0 01.12.2015 18:12
kurthatlevik: DAX2012R3CU9 – DIXF – Automate import/export without customizations Blog bot DAX Blogs 0 28.10.2015 20:11
kurthatlevik: DAX2012R3CU9 – DIXF – Automate import/export without customizations Blog bot DAX Blogs 0 21.08.2015 16:11
Часовой пояс GMT +3, время: 02:11.
