Старый 23.03.2017, 11:11   #1
D365O. Issues with Microsoft Dynamics App for Office setup.
Источник: https://ievgensaxblog.wordpress.com/...-office-setup/
Recently I’ve helped my colleague to setup Word Templates for D365O. We followed Office integration tutorial on the wiki, but it has few gaps.
First of all, it’s not clear where to find share that contains the Microsoft Dynamics App manifest ( step 1.d). Use base URL for the cloud environment, for example, https://topo00dfa4stbobaos.cloudax.test.dynamics.com/
Second step where we stuck for a while is not so obvious. 4.b says that you need to select Template Designer after loading applets. However, there was nothing to select. To fix this issue you actually need to go to D365O -> System Administration -> Setup -> Office app parameters and on “Registered applets” tab check that there is a record for Microsoft.Dynamics.Platform.Integration.Office.WordDesignerApplet in a grid.
If it’s not there click on “Initialize applet registration” button and AX will auto populate the grid.
NAV Team: Validating Single Sign-on with Office 365 and Microsoft Dynamics NAV 2013 R2 Blog bot Dynamics CRM: Blogs 0 19.12.2013 15:00
Microsoft Dynamics CRM Team Blog: Update Rollup 3 for Microsoft Dynamics CRM 2011 Blog bot Dynamics CRM: Blogs 3 03.08.2011 09:11
Microsoft Dynamics NAV Database Archive for all Country Versions Blog bot Dynamics CRM: Blogs 0 11.03.2011 18:43
Часовой пояс GMT +3, время: 03:42.
