Старый 20.02.2016, 08:34   #2
KiselevSA is offline
KiselevSA
Аватар для KiselevSA
958 / 333 (13) ++++++
Вырезка из статьи на technet:
Language translations are supported if you use Microsoft SQL Server 2008 Enterprise Edition or Microsoft SQL Server 2008 R2 or later for your Analysis Services server. Do not include translations in the project if you are using a Microsoft SQL Server 2008 Standard Edition Analysis Services server. If you do and you get an error, you can delete the Analysis Services project in the AOT and then redeploy the Analysis Services project by using the SQL Server Analysis Services project update wizard.
Статья -> https://technet.microsoft.com/en-us/.../gg724140.aspx
analisis service, ax2012r3
atinkerersnotebook: Using Service Management to Track Service Orders Blog bot DAX Blogs 1 25.08.2013 19:16
AIF: Microsoft Dynamics AX Services and Windows Azure Service Bus Blog bot DAX Blogs 0 24.07.2013 03:13
emeadaxsupport: AX for Retail 2012 R2: Installing the Real-time Service Blog bot DAX Blogs 0 19.12.2012 11:11
DynamicsAxSCM: Service products in Microsoft Dynamics AX 2012 Blog bot DAX Blogs 2 02.06.2011 13:36
Часовой пояс GMT +3, время: 01:37.
