Старый 28.08.2015, 12:13   #1
rkorchagin is offline
rkorchagin
Я не писал запросы к таблице, а старался всё сделать через классы... Вот пример моего кода из С#
public void OMPPrintAxaptaProcess(string _dummy, string _dummy1)
            // Create an instance of the Axapta class.
            Axapta DynAx = new Axapta();
            AxaptaObject axObj = null;
            DateTime startTime = DateTime.Now;
            // Add the proxy user.
            // Replace the ProxyUserID and password parameters with the
            // proxy user name and password that you specified
            // in the Business Connector Proxy.
            //System.Net.NetworkCredential nc = new System.Net.NetworkCredential(Global.userName,Global.userPassword,Global.domain);
            //string _filename = Global.filename2process;
            object ret = null;
            bool logged = false;
            // Test the connection to the .NET Business Connector.
            try
                //DynAx.LogonAs(Global.userName.Trim(),
                //    Global.domain,
                //    nc,
                //    Global.daxcompany,
                //    Global.daxlanguage,
                //    Global.daxobjectserver,
                //    Global.daxconfiguration);
                DynAx.Logon(Global.daxcompany,
                    Global.daxlanguage,
                logged = true;
                infoMessageEvent("OMP print DAX: Logon successful", EventLogEntryType.SuccessAudit);
                axObj = DynAx.CreateAxaptaObject("SEPProcessOMPLabels");
                axObj.Call("parmServiceInstanceId", Global.ompServiceInstanceId);
                ret = axObj.Call("run");
                if (ret != null &&
                    ret.GetType().ToString() == "System.Boolean" &&
                    ((bool)(ret)))
                    infoMessageEvent("OMP print DAX: completed", EventLogEntryType.Information);
                else
                    infoMessageEvent("OMP print DAX: failed", EventLogEntryType.Information);
                DynAx.Logoff();
                logged = false;
                infoMessageEvent("OMP print DAX: Logoff completed.", EventLogEntryType.SuccessAudit);
            catch (Exception ex)
                if (logged)
                    DynAx.Logoff();
                    logged = false;
                infoMessageEvent("OMP print DAX: " + ex.Source + "/" + ex.Message, EventLogEntryType.Error);
            finally
                if (axObj != null)
                    axObj.Dispose();
                if (DynAx != null)
                    DynAx.Dispose();
            infoMessageEvent("OMP print DAX Time used: " + Convert.ToString(DateTime.Now - startTime), EventLogEntryType.Information);
Developer for Microsoft Dynamics AX Certification Roadmap Blog bot DAX Blogs 1 13.05.2009 16:17
Часовой пояс GMT +3, время: 01:40.
