Старый 31.05.2011, 22:11   #1
Microsoft Dynamics CRM Team Blog: Using Option Set Options with the REST Endpoint – JScript
Источник: http://blogs.msdn.com/b/crm/archive/...t-jscript.aspx
I recently published a new technical article for Microsoft Dynamics CRM 2011 and Microsoft Dynamics CRM Online: Using Option Set Options with the REST Endpoint – JScript.
This article is about using option set attribute metadata to:
  • Display text for integer values returned for option sets
  • Display valid options for user interface controls to allow editing records
These tasks are presented in the context of a sample JScript library that can be used to generate a simple user interface with an HTML Web resource. This is the UI for a page displaying Contact entity records:
This sample is only intended to illustrate the strategy described in the article. It is intentionally as simple as I could make it while still covering the core tasks to create, retrieve, update and delete records containing option set attributes. Along the way I also used attribute metadata to manage:
  • Setting default values for new records
  • Enforcing required fields
  • Preserving the integrity of auditing data by only updating attributes that are changed
If you need to create a user interface to edit Microsoft CRM record I hope this article helps you identify the attribute metadata you can use.
Cheers,
Jim Daly
Microsoft Dynamics CRM Team Blog: Released! Customer Care Accelerator for Microsoft Dynamics CRM 2011 Blog bot Dynamics CRM: Blogs 0 13.05.2011 23:12
Microsoft Dynamics CRM Team Blog: Microsoft Dynamics CRM Online Upgrades Blog bot Dynamics CRM: Blogs 0 12.02.2011 00:11
Microsoft Dynamics CRM Team Blog: Workflow E-mail Utilities Blog bot Dynamics CRM: Blogs 0 16.12.2008 23:05
Часовой пояс GMT +3, время: 21:55.
