Старый 06.05.2009, 19:05   #1
25,643 / 848 (80) +++++++
Jim Wang: CRM 4.0 IFrame: Show Entity's Associated View
Источник: http://jianwang.blogspot.com/2009/05...ssociated.html
It's a common requirement to show entity's associated view(1:N, N:N) in IFrame, the below code works for both 1:N and N:N relationship, it also works on works on both On-Premise and IFD deployment. All you need to do is find out(IE Developer Toolbar) the ID of the associated link.
The 1:N relationship needs these parameters in the request URL: oId, oType, security, tabSet
The N:N relationship needs an extra parameter: roleOrd in the request URL, which has been involved in the code.
var navId = "nav_new_new_myentity_account";
if(document.getElementById(navId) != null)
var tmp = document.getElementById(navId).onclick.toString();
tmp = tmp.substring(tmp.indexOf("'")+1, tmp.indexOf(";"));
var loadArea = tmp.substring(0, tmp.indexOf("'"));
var roleOrd = (tmp.indexOf("roleOrd") == -1) ? -1 : tmp.substring( tmp.indexOf("roleOrd"), tmp.lastIndexOf("'")).replace("\\x3d", "=");
crmForm.all.IFRAME_view.src = (roleOrd == -1) ? GetFrameSrc(loadArea) : GetFrameSrc(loadArea) + "&" + roleOrd;
function GetFrameSrc(tabSet)
if (crmForm.ObjectId != null)
var id = crmForm.ObjectId;
var type = crmForm.ObjectTypeCode;
var security = crmFormSubmit.crmFormSubmitSecurity.value;
var path = document.location.pathname.substring(0, document.location.pathname.indexOf("edit.aspx")) + "areas.aspx?";
return (path + "oId=" + id + "&oType=" + type + "&security=" + security + "&tabSet=" + tabSet);
else
return "about:blank";
Enjoy it! ;-)
Jim Wang: Show both active and inactive records in the lookup view Blog bot Dynamics CRM: Blogs 0 30.04.2009 02:08
Jim Wang: Customizing CRM by Using the Microsoft Dynamics CRM Developer Toolkit Blog bot Dynamics CRM: Blogs 0 09.04.2009 22:05
Jim Wang: Get Entity/Attribute's Display Name from CRM database Blog bot Dynamics CRM: Blogs 0 28.03.2009 01:05
Jim Wang: CRM 4.0 Get attribute value from entity's GUID using JScript Blog bot Dynamics CRM: Blogs 0 11.02.2009 06:05
Часовой пояс GMT +3, время: 13:28.
