Старый 05.02.2009, 15:11   #2
Eldar9x is offline
Eldar9x
Аватар для Eldar9x
Oracle
1,064 / 166 (8) ++++++
Из доков
PerformFormLookup calls the SelectMode and SelectTarget methods (also in the FormControlName class) on the form given as argument. These two methods set the form in SelectMode and identify where the value is to be inserted (using the SelectTarget method).
Alternatively, you can call SelectMode yourself, passing a control in the lookup form as parameter. The value of the control will be pasted in the target control. In this case you do not have to pass a string as parameter to CloseSelect.
gatesasbait: How to define a custom lookup form for an extended datatype Blog bot DAX Blogs 0 09.07.2008 22:05
Lookup даты для выбора месяца Antidot DAX: Программирование 0 21.01.2005 21:24
Lookup поля в Гриде NeveB DAX: Программирование 1 10.12.2003 12:18
Динамические Lookup формы. Андрей Василюк DAX: База знаний и проекты 0 07.12.2001 07:07
Часовой пояс GMT +3, время: 14:54.
