Старый 27.06.2007, 21:40   #1
25,644 / 848 (80) +++++++
Kashperuk Ivan: Tabax plugins' update - RecentWindows, RecentProjects
Источник: http://kashperuk.blogspot.com/2007/0...ntwindows.html
After developing 3 great tabax plugins I was feeling a little unsatisfied, because I wanted to add images to the popup menues.
AndyD has developed a class that allows me to do this now.
The project containing the class with the images is "shipped" separately. Depending on where you want to see images in your popups menues or not, you will be able to import it separately if you do.
Download:
You can use the following links to download the projects (version 0.1.1) and the MenuImages class.
RecentProjects v. 0.1.1 -download
RecentWindows v. 0.1.1 - download
Class MenuImages - download
Alternatively you can download them from their homepages on Axaptapedia.
RecentProject - homepage
RecentWindows - homepage
Screenshot: (RecentWindows)
Kashperuk Ivan: Microsoft Dynamics AX 2009 Keyboard shortcuts Blog bot DAX Blogs 5 18.12.2013 18:24
Kashperuk Ivan: A bug in validation of methods' access modifiers and class abstract modifier Blog bot DAX Blogs 0 27.06.2007 21:40
Kashperuk Ivan: 3 great Tabax Plugins Blog bot DAX Blogs 2 15.05.2007 11:55
Kashperuk Ivan: Buy MorphX IT in Russian Blog bot DAX Blogs 6 13.04.2007 17:48
Kashperuk Ivan: AxCreateNewProject version 1.3.1 availableI have... Blog bot DAX Blogs 0 08.02.2007 22:31
Часовой пояс GMT +3, время: 10:13.
