Старый 19.03.2007, 15:14   #6
sergeypp is offline
sergeypp
Ищу людей. Дорого.
Аватар для sergeypp
433 / 174 (6) ++++++
пишу след запрос
select Closed, count(*) from inventsum
group by Closed
вот результат
Closed
0 396231
1 923596
просто при использовании некластерного индекса в планах появляется еще и Bookmark Lookup
вот два плана. .с использованием индекса и нет
1           1             |--Compute Scalar(DEFINE:([Expr1002]=If ([Expr1015]=0) then NULL else [Expr1016], [Expr1003]=If ([Expr1015]=0) then NULL else [Expr1017]))        46          2           1           Compute Scalar                 Compute Scalar                 DEFINE:([Expr1002]=If ([Expr1015]=0) then NULL else [Expr1016], [Expr1003]=If ([Expr1015]=0) then NULL else [Expr1017])                                                        [Expr1002]=If ([Expr1015]=0) then NULL else [Expr1016], [Expr1003]=If ([Expr1015]=0) then NULL else [Expr1017]  1.0                      0.0                      1.6147925E-6             41          9.701564E-3              [Expr1002], [Expr1003]                                 NULL     PLAN_ROW                       0        1.0
1           1                  |--Stream Aggregate(DEFINE:([Expr1015]=Count(*), [Expr1016]=SUM([A].[POSTEDQTY]), [Expr1017]=SUM([A].[POSTEDVALUE])))        46          3           2           Stream Aggregate               Aggregate                      NULL        [Expr1015]=Count(*), [Expr1016]=SUM([A].[POSTEDQTY]), [Expr1017]=SUM([A].[POSTEDVALUE])                         1.0                      0.0                      1.6147925E-6             41          9.701564E-3              [Expr1015], [Expr1016], [Expr1017]                     NULL     PLAN_ROW                       0        1.0
22          1                       |--Nested Loops(Inner Join, OUTER REFERENCES:([A].[INVENTDIMID]) WITH PREFETCH)        46          4           3           Nested Loops                   Inner Join                     OUTER REFERENCES:([A].[INVENTDIMID]) WITH PREFETCH        NULL        16.147924                0.0                      6.7498324E-5             337         9.6999491E-3             [A].[POSTEDQTY], [A].[POSTEDVALUE]                     NULL     PLAN_ROW                       0        1.0
22          1                            |--Bookmark Lookup(BOOKMARK:([Bmk1000]), OBJECT:([domoNew].[dbo].[INVENTSUM] AS [A]))        46          6           4           Bookmark Lookup                Bookmark Lookup                BOOKMARK:([Bmk1000]), OBJECT:([domoNew].[dbo].[INVENTSUM] AS [A])        [A].[INVENTDIMID], [A].[POSTEDQTY], [A].[POSTEDVALUE]                                                           16.147924                7.8122527E-4             1.7762717E-5             234         4.098813E-3              [A].[INVENTDIMID], [A].[POSTEDQTY], [A].[POSTEDVALUE]  NULL     PLAN_ROW                       0        1.0
22          1                            |    |--Index Seek(OBJECT:([domoNew].[dbo].[INVENTSUM].[I_174CLOSEDITEMDIMIDX] AS [A]), SEEK:([A].[DATAAREAID]='dat' AND [A].[CLOSED]=0 AND [A].[ITEMID]='0000005') ORDERED FORWARD)                                                            46          8           6           Index Seek                     Index Seek                     OBJECT:([domoNew].[dbo].[INVENTSUM].[I_174CLOSEDITEMDIMIDX] AS [A]), SEEK:([A].[DATAAREAID]='dat' AND [A].[CLOSED]=0 AND [A].[ITEMID]='0000005') ORDERED FORWARD, FORCEDINDEX  [Bmk1000]        16.147924                3.2034011E-3             9.6424199E-5             78          3.2998251E-3             [Bmk1000]                                              NULL     PLAN_ROW                       0        1.0
22          22                           |--Clustered Index Seek(OBJECT:([domoNew].[dbo].[INVENTDIM].[I_698DIMIDIDX] AS [B]), SEEK:([B].[DATAAREAID]='dat' AND [B].[INVENTDIMID]=[A].[INVENTDIMID]) ORDERED FORWARD)        46          9           4           Clustered Index Seek           Clustered Index Seek           OBJECT:([domoNew].[dbo].[INVENTDIM].[I_698DIMIDIDX] AS [B]), SEEK:([B].[DATAAREAID]='dat' AND [B].[INVENTDIMID]=[A].[INVENTDIMID]) ORDERED FORWARD, FORCEDINDEX                NULL        1.0                      3.2034011E-3             7.9607002E-5             111         5.5336375E-3             NULL                                                   NULL     PLAN_ROW                       0        16.147924
1           1             |--Compute Scalar(DEFINE:([Expr1002]=If ([Expr1015]=0) then NULL else [Expr1016], [Expr1003]=If ([Expr1015]=0) then NULL else [Expr1017]))        49          2           1           Compute Scalar                 Compute Scalar                 DEFINE:([Expr1002]=If ([Expr1015]=0) then NULL else [Expr1016], [Expr1003]=If ([Expr1015]=0) then NULL else [Expr1017])                                                        [Expr1002]=If ([Expr1015]=0) then NULL else [Expr1016], [Expr1003]=If ([Expr1015]=0) then NULL else [Expr1017]  1.0                      0.0                      1.6147925E-6             41          1.1219452E-2             [Expr1002], [Expr1003]                                               NULL     PLAN_ROW         0        1.0
1           1                  |--Stream Aggregate(DEFINE:([Expr1015]=Count(*), [Expr1016]=SUM([A].[POSTEDQTY]), [Expr1017]=SUM([A].[POSTEDVALUE])))        49          3           2           Stream Aggregate               Aggregate                      NULL        [Expr1015]=Count(*), [Expr1016]=SUM([A].[POSTEDQTY]), [Expr1017]=SUM([A].[POSTEDVALUE])                         1.0                      0.0                      1.6147925E-6             41          1.1219452E-2             [Expr1015], [Expr1016], [Expr1017]                                   NULL     PLAN_ROW         0        1.0
22          1                       |--Nested Loops(Inner Join, OUTER REFERENCES:([A].[INVENTDIMID]) WITH PREFETCH)        49          4           3           Nested Loops                   Inner Join                     OUTER REFERENCES:([A].[INVENTDIMID]) WITH PREFETCH        NULL        16.147924                0.0                      6.7498324E-5             337         1.1217837E-2             [A].[POSTEDQTY], [A].[POSTEDVALUE]                                   NULL     PLAN_ROW         0        1.0
22          1                            |--Clustered Index Seek(OBJECT:([domoNew].[dbo].[INVENTSUM].[I_174ITEMDIMIDX] AS [A]), SEEK:([A].[DATAAREAID]='dat' AND [A].[ITEMID]='0000005'),  WHERE:([A].[CLOSED]=0) ORDERED FORWARD)                                                       49          6           4           Clustered Index Seek           Clustered Index Seek           OBJECT:([domoNew].[dbo].[INVENTSUM].[I_174ITEMDIMIDX] AS [A]), SEEK:([A].[DATAAREAID]='dat' AND [A].[ITEMID]='0000005'),  WHERE:([A].[CLOSED]=0) ORDERED FORWARD, FORCEDINDEX  [A].[INVENTDIMID], [A].[CLOSED], [A].[POSTEDQTY], [A].[POSTEDVALUE]                                             16.147924                2.7128116E-3             7.8514153E-5             234         5.5826516E-3             [A].[INVENTDIMID], [A].[CLOSED], [A].[POSTEDQTY], [A].[POSTEDVALUE]  NULL     PLAN_ROW         0        1.0
22          22                           |--Clustered Index Seek(OBJECT:([domoNew].[dbo].[INVENTDIM].[I_698DIMIDIDX] AS [B]), SEEK:([B].[DATAAREAID]='dat' AND [B].[INVENTDIMID]=[A].[INVENTDIMID]) ORDERED FORWARD)        49          7           4           Clustered Index Seek           Clustered Index Seek           OBJECT:([domoNew].[dbo].[INVENTDIM].[I_698DIMIDIDX] AS [B]), SEEK:([B].[DATAAREAID]='dat' AND [B].[INVENTDIMID]=[A].[INVENTDIMID]) ORDERED FORWARD, FORCEDINDEX                NULL        1.0                      3.2034011E-3             7.9607002E-5             111         5.5336375E-3             NULL        NULL     PLAN_ROW         0        16.147924
Как формируется в Axapta название табличного индекса для СУБД? dn DAX: База знаний и проекты 4 09.10.2007 16:21
Волшебное превращение неуникального индекса... IPv6 DAX: База знаний и проекты 4 10.01.2007 16:46
Блокировка ключа индекса Sequel DAX: Программирование 4 06.07.2006 16:08
Использование индекса по RecId не разрешено! 3oppo DAX: Программирование 1 25.07.2005 14:54
Отображение связных таблиц. Сплиттер. Автоувеличение индекса. Delete Action. sguryev DAX: База знаний и проекты 0 14.12.2001 06:15
Часовой пояс GMT +3, время: 13:15.
