Старый 09.09.2021, 04:51   #1
d365technext: Environment Hot-Fixes List Using D365FO
Источник: https://d365technext.blogspot.com/20...OHotfixes.html
Environment Hot-Fixes List Using X++ D365FO
We All know that information about metadata hotfixes is installed directly from Visual Studio and we can check them Using Apply Hotfix Addins(Dynamics 365 -> Addins -> Apply Hotfix).
The same things we can retrieve using X++ Job
Code Sample
class SLD_DemoClass
public static void main(Args _args)
new SLD_DemoClass().processExecution();
public void processExecution()
var environment = Microsoft.Dynamics.ApplicationPlatform.Environment.EnvironmentFactory::GetApplicationEnvironment();
Microsoft.Dynamics.AX.Metadata.Providers.IMetadataProvider metadataProvider = this.getDiskMetadataProvider(environment);
Microsoft.Dynamics.AX.Metadata.Providers.IMetaUpdateProvider updateProvider = metadataProvider.get_Updates();
var moduleInfoList = metadataProvider.ModelManifest.ListModules();
var i = moduleInfoList.GetEnumerator();
setPrefix('Installed KBs on your Instance');
while (i.MoveNext())
Microsoft.Dynamics.AX.Metadata.MetaModel.IModuleInfo moduleInfo = i.get_Current();
System.String moduleName = moduleInfo.get_Name();
setPrefix(moduleName);
var updatesHotfixesEnumerator = updateProvider.ListObjects(moduleName).GetEnumerator();;
while (updatesHotfixesEnumerator.moveNext())
System.String axUpdateName = updatesHotfixesEnumerator.get_Current();
Microsoft.Dynamics.AX.Metadata.MetaModel.AxUpdate axUpdateObject = updateProvider.Read(axUpdateName);
utcdatetime installedDateTime = axUpdateObject.get_AppliedDateTime();
setPrefix(strFmt('Name %1, Installed on %2', axUpdateObject.get_Name(), installedDateTime));
var listKb = axUpdateObject.get_KBNumbers().GetEnumerator();
while (listKb.MoveNext())
info(listKb.get_Current());
public Microsoft.Dynamics.AX.Metadata.Providers.IMetadataProvider getDiskMetadataProvider(Microsoft.Dynamics.ApplicationPlatform.Environment.IApplicationEnvironment _Instance)
Microsoft.Dynamics.AX.Metadata.Storage.DiskProvider.DiskProviderConfiguration diskProviderConfiguration = new Microsoft.Dynamics.AX.Metadata.Storage.DiskProvider.DiskProviderConfiguration();
diskProviderConfiguration.AddMetadataPath(_Instance.get_Aos().get_PackageDirectory());
Microsoft.Dynamics.AX.Metadata.Storage.MetadataProviderFactory metadataProvicerFactory = new Microsoft.Dynamics.AX.Metadata.Storage.MetadataProviderFactory();
return metadataProvicerFactory.CreateDiskProvider(diskProviderConfiguration);
d365technext: List of Tables X++ D365FO, AX7 and AX2012 Blog bot DAX Blogs 0 10.09.2018 18:11
d365technext: Environment hot fixes D365FO Blog bot DAX Blogs 0 16.08.2018 14:11
d365technext: Environment Hot-Fixes List Using X++ D365FO & AX 7 Blog bot DAX Blogs 0 02.08.2018 18:12
yetanotherdynamicsaxblog: List hotfixes using PowerShell in D365FO (AX7) Blog bot DAX Blogs 0 13.01.2018 20:21
Microsoft Dynamics CRM Team Blog: Marketing with Dynamic List Blog bot Dynamics CRM: Blogs 0 09.11.2010 19:05
Часовой пояс GMT +3, время: 18:07.
