Старый 12.04.2018, 06:16   #1
stoneridgesoftware: Quick Modification for Tracing Bug Code in a Dynamics AX Production Environment
Источник: https://stoneridgesoftware.com/quick...n-environment/
This quick modification for tracing bug code in a Dynamics AX production environment was used at a client site. I have received their permission to blog about this as I thought it was pretty useful.
Basically, the modification consists of the creation of an empty security role. When a user reports a bug, they may be asked for more detailed repro steps within the production environment. The user will be added to this security role, which will trigger the dumping of the X++ call stack into the Infolog when the error is generated. Once the repro is complete, the user is simply removed from the security role, and the logging is stopped. For the bug repro, the user may need to have running code in CIL disabled so the full call stack can be retrieved as well.
Part 1. Create an empty security role in the system
  • Navigate in the Dynamics AX 2012 client System administration > Setup > Security > Security roles
  • Click the New button
  • Fill in pertinent information
  • Click the Close button
Part 2. Modify the info class, add() method
Change the method to the following code (no changes in the latter half of the method, so just make the displayed modifications:
Exception add( Exception _exception, str _txt, str _helpUrl = '', Object _sysInfoAction = null, boolean buildprefix = true){ int numOfLines,i; int actionClassId; container packedAction; xSession session; // START - Add callstack to infolog #Define.mySecurityRole('EnableAXDebugging') System.Diagnostics.StackTrace myStackTrace; container myCallStack; int cntr; str1260 whatToWrite; SecurityUserRole securityUserRole; SecurityRole securityRole; boolean dumpCallStack = false; while select AotName from securityRole join securityUserRole where securityUserRole.User == curUserId() && securityUserRole.SecurityRole == securityRole.RecId { if (securityRole.AotName == #mySecurityRole) { // if we find the security role, set our X++ call stack dump variable, and quit searching as we are done dumpCallStack = true; break; } } if (dumpCallStack) { // determine if running as native X++ or as IL code if (xSession::isCLRSession()) // IL code { myStackTrace = new System.Diagnostics.StackTrace(true); _txt += ' - ' + myStackTrace.ToString(); } else { myCallStack = xSession::xppCallStack(); for(cntr=1; cntr Common > Users. Select the user by double-clicking, and add the security role to the user by clicking the Assign roles button</p>
Click the OK button once the debugging role has been selected.
Part 4. If needed, disable running business logic in CIL
In the client, navigate File > Tools > Options > Development tab. Uncheck the Execute business operations in CIL checkbox
Click the Close button.
At this point, you should be able to run a process, and see the call stack in the Infolog when the error is generated.
Once this has been captured, simply go back into the user, and remove the debugging security role from the user. If the Execute business operations in CIL checkbox was modified, go back and correct that setting as well.
I hope that you find this useful, and it provides you something you can add to your ‘bag of tricks’ for debugging or troubleshooting any Dynamics AX issues.
Старый 12.04.2018, 11:22   #2
trud is offline
trud
1,039 / 1635 (57) ++++++++
Записей в блоге: 1
Как-то не очень хорошая идея добавлять безусловный join в вызов info.
в параметры пользователя тоже добавить галку- "показывать стек" не очень хорошая идея, ибо можно вызвать ошибку SQL при неотсинхронизированной таблице. т.е. что-то с глобальным кешем надо мудрить.
кто-нибудь кстати делал подобное, как решали?
Старый 12.04.2018, 12:37   #3
skuull is offline
skuull
700 / 752 (27) +++++++
Та какой-то сомнительный блог. В одном месте они говорят что надо выключить CIL, а в другом проверяю а не CIL ли это (xSession::isCLRSession()), вместо селекта на каждую ошибку могли бы закешить флажок.
И опять же, если пользователь может воспроизвести ошибку то сделать рестор данных на энвайромент с дебагом легче легкого, а если он не может то он роль себе не влючит и толку от этой свистопляски 0.
Старый 12.04.2018, 14:25   #4
online
fed
Аватар для fed
2,914 / 5737 (197) ++++++++++
Сообщение от skuull Посмотреть сообщение
Я просто замечу что у меня сейчас в самом большом по объему данных проекте, размер БД - 1.8Tbytes. Бэкап занимает порядка 6 часов, подъем из бэкапа - порядка 4. Кроме того, клиент свои сервера зааутсорсил в дата-центр и тамошние специалисты не всегда готовы перекидывать данные по первому требованию. Так что - не всегда это "легче легкого".
Самый большой объем данных на аксаптовском внедрении, о котором я слышал - что-то около 70 террабайт. Советую прикинуть, насколько легко там перекинуть данные в отладочное окружение.
Кроме того, далеко не всегда пользователь может воспроизвести ошибку. Она может случайным образом (например в ситуации со сложными блокировками) случатся раз в месяц, при этом на уровне одного конечного пользователя, условия ее воспроизведения не возможно определить.
Так что сама по себе идея вполне полезная. Возможно есть погрешности в реализации, но право на жизнь она вполне имеет.
Старый 12.04.2018, 15:35   #5
Wamr is offline
Wamr
1,737 / 868 (32) +++++++
Записей в блоге: 7
Делали табличку, в которую писались ошибки из инфолога с автором, временем и стеком.
Очень удобно было разбирать ошибки "у нас тут что-то выскочило, но мы испугались и закрыли"
stoneridgesoftware: How to Process a Partial Pick List in Production from Dynamics AX Blog bot DAX Blogs 0 19.05.2017 19:11
german_nav_developer: Buildnummern-Übersicht Microsoft Dynamics NAV 2009 SP1 Blog bot Dynamics CRM: Blogs 0 11.06.2010 16:33
Часовой пояс GMT +3, время: 09:43.
