Вернуться   AXForum > Microsoft Dynamics AX > DAX: За рубежом > DAX in English
Старый 27.04.2009, 12:58   #1
Hugon is offline
Hugon
AX 4 Automatic filling field
Hi All,
While creating new record, or during saving new record, I want system filled the field ToDate in the previous record automatically. ie
record 1:
Descr.| FromDate | ToDate
test1 | 10/10/2008 |
record 2:
test2 | 15/10/2008 |
save -> system should filled ToDate in previous record now.
Final result should be:
test1 | 10/10/2008 | 14/10/2008
Does something like this exist in AX? Could you give me table name or help how
to do this?
Thank you in advance
Hugon
______________________
AX Developer .::. Beginner
Последний раз редактировалось Hugon; 27.04.2009 в 13:05.
Старый 27.04.2009, 13:13   #2
Wamr is offline
Wamr
1,737 / 868 (32) +++++++
Записей в блоге: 7
void insert()
    YourTable  yourTable;
    super();
    update_recordset yourTable
    setting ToDate = this.FromDate - 1
    where yourTable.FromDate < this.FromDate
       && ! yourTable.ToDate;
Последний раз редактировалось Wamr; 27.04.2009 в 13:16.
За это сообщение автора поблагодарили: Hugon (1).
Старый 27.04.2009, 18:46   #3
Hugon is offline
Hugon
Thanks a lot.
Hugon
ax4.0
Arijit Basu: Reporting & BI in AX: An Overview [Level 100] Blog bot DAX Blogs 0 07.01.2008 16:01
casperkamal: Adding a Table field through X++ code in Dynamics Ax Blog bot DAX Blogs 1 02.04.2007 17:05
Часовой пояс GMT +3, время: 16:34.
