Старый 04.04.2008, 11:05   #1
25,751 / 851 (80) +++++++
msdynamicsax: Integrated Version Control
Источник: http://msdynamicsax.wordpress.com/20...oper-features/
One of the major new developer tools is the fully integrated version control system within MorphX. In DAX 4.0 you had to use either Visual Source Safe or Team Foundation Server and each of the developers in a project had to have their own AOS. Basically it was not usable at all for VAR’s but fitted better for ISV’s. (The VSS and TF versions are still available in DAX 2009). The MorphX VCS is very easy to use and it lets the users check in/out single objects and projects, make comments on each check-in, all checked-out elements are marked with blue font-color (default) in the AOT. Checked-in elements are locked (and the locking now actually works). You can aslo add rules so that when trying to check-in code that does not follow best practice rules, has compilor warnings, compilor errors, or compiler TO-DO’s you will get an error.
The way the basis for the MorphX VCS works is that it has a repository consisting of metadata regarding each element alongside an xpo-file.
MorphX VCS History form
KUDOS to the MS Dax Ax tools dev team in Redmond for this feature.
palleagermark: Channel 9 video: Dynamics AX Version Control interview from Convergence in Copenhagen 2008 Blog bot DAX Blogs 0 30.01.2009 16:05
mfp: Dynamics AX 2009 Version Control Interview Blog bot DAX Blogs 0 28.01.2009 12:05
axStart: Microsoft Dynamics AX 2009 White Paper: Team Foundation Server Version Control Setup Blog bot DAX Blogs 0 27.07.2008 13:06
Channel9: Version control in MorphX Blog bot DAX Blogs 8 25.12.2007 10:37
DynamicsTech: How to do the setup for Version Control System in Ax 4.0 Blog bot DAX Blogs 0 12.04.2007 11:50
Часовой пояс GMT +3, время: 02:48.
