Старый 22.04.2010, 16:05   #1
25,644 / 848 (80) +++++++
Kashperuk Ivan: Tool: User preferred startup menu for Dynamics AX 2009
Источник: http://kashperuk.blogspot.com/2010/0...-menu-for.html
In AX 2009, the user has no control over which menu is opened in the navigation pane and address bar when AX client is started.
Most of the time you simply get the Home page, which is frustrating for a number of users. Another thing that is frustrating for them is the company account the application opens with.
The latter can actually be setup using standard application functionality in the User options form. Just set the 'Start company accounts' to the account you want for the user by default.
I wrote a small tool, that allows the user to select a preferred startup menu, ensuring that this menu is the one open every time AX client is started. Something similar existed in Axapta 3.0 application.
You can download the xpo for this tool from my SkyDrive.
Note, that it contains minor changes to a number of existing application objects.
I suggest that you compare the xpo from the import dialog and ensure that you don't override any of your changes during import - the best thing would be to re-implement these minor changes manually. Below is a list of changes that I am referring to above:
  • SysUserInfo table - 1 new field was added
  • SysUserSetup form - 1 new control was added. Lookup method on datasource field overridden
  • Info class - startupPost method changed
In order to enable the functionality, simply select one of the menus in the User options, as shown in the below screenshot. Next time you start AX, the selected menu will be open by default.
Below is a short listing of "code patterns" used in the project, that can serve as examples for your future projects:
  • SysTableLookup - for displaying a lookup form with a list of menus
  • infolog.globalCache() - for storing a global reference to the navigator class
  • TreeNode iteration - for finding all menu references in MainMenu
  • QueryBuild classes - for constructing and filtering a list of menu references in MainMenu, used in the lookup form
  • infolog.addTimeOut() method - for scheduling execution of another method in a set period of time
Старый 22.04.2010, 22:49   #2
kashperuk is offline
kashperuk
Аватар для kashperuk
4,361 / 2084 (78) +++++++++
Общественности с этого форума этот проект скорее всего будет пока что неинтересен, так как в России, как я понимаю, очень мало проектов пока с АХ 2009.
Возможно в будущем пригодится
За это сообщение автора поблагодарили: AlGol (1), gl00mie (1), alex55 (1).
ax2009, главное меню, законченный пример, полезное
Kashperuk Ivan: Microsoft Dynamics AX 2009 Keyboard shortcuts Blog bot DAX Blogs 5 18.12.2013 18:24
Kashperuk Ivan: Run AX as a different user from Windows Explorer Blog bot DAX Blogs 0 15.01.2010 02:09
Kashperuk Ivan: Inside Dynamics AX 2009 – Russian Translation Blog bot DAX Blogs 2 25.08.2009 12:18
Часовой пояс GMT +3, время: 20:49.
