Старый 31.10.2008, 22:05   #1
25,644 / 848 (80) +++++++
Debugging code on Business Connector
Источник: http://alexvoy.blogspot.com/2008/10/...connector.html
As MSDN our suggests, first, we should enable Debugger on the client, (do not be confused with versions! my previous link is correct for AX 4.0 and AX 2009 too, but this is only for AX 3.0)
Then, we must to enable the same on the Business Connector with Configuration Utility: (in my case I had to check both in order to debug my web service)
Now, you can add a breakpoint in your code.
Finally, you should run an instance of Debugger manually from the client's main menu because it does not start automatically as usually.
In conclusion I need to say that you should log in on your debugged application with the same user account which was used for the client and debugger sessions.
Lucky hunt for bugs!
Vincent: Debugging business logic in AX 2009 SSRS reports Blog bot DAX Blogs 0 29.11.2008 09:05
Arijit Basu: DAX 4.01 .NET Business Connector: Microsoft.Dynamics.BusinessConnectorNet Blog bot DAX Blogs 3 30.09.2008 01:17
Inside Dynamics AX 4.0: Working with the .NET Business Connector Blog bot DAX Blogs 0 04.10.2007 05:15
Inside Dynamics AX 4.0: Inside the Business Connector Blog bot DAX Blogs 0 04.10.2007 05:15
ALEG: Проект "Фишка недели" и первый пост - Microsoft Dynamics™ AX .NET Business Connector Blog bot DAX Blogs 1 22.11.2006 09:43
Часовой пояс GMT +3, время: 08:48.
