This overview of KB-releases and build numbers, is an extension to this one:
"Servicepacks & Platform Updates for Microsoft Dynamics NAV" Links in the table are to the corresponding documentation on PartnerSource (login required), where available. DBVersionno for all builds = 95. 5 Sp1 Build KB Number Released Description Update 1 27191 956161 21/08/2008 Platform Update 1 for NAV 5 SP1. 27199 957276 28/08/2008 In some cases, when filtering, fin.exe and finsql.exe may return different results. 27241 957267 27/08/2008 DBCS character display is inconsistent when entering more characters than are visible in a text box 27253 954722 27/08/2008 NAV may crash when opening and closing many forms that run modally. Often with error 1247 in module 19. 27368 957219 12/09/2008 BizTalk - Sending a document returns error, even if the document was sent OK. 27368 957471 16/09/2008 Backup/Restore of single company can cause - "Company Name <companyname> does not exist" error - Native only 27368 957733 23/09/2008 Indexed views always rebuilt when compiling/modifying/importign table objects in SP1 27398 957824 17/09/2008 Changes in Production Schedule are not saved - Native only 27831 959911 13/11/2008 XMLPort.EXPORT cannot handle DBCS Characters. 27831 959912 13/11/2008 Permissions too restrictive when calculating flowfields with security filters (recordlevel security) 27831 960141 17/11/2008 RunModal error screen when deleting record links in certain cases 28007 960607 01/12/2008 Save report to html can save the wrong space characters. 28028 960661 09/12/2008 Lookup list in report request forms do not open. 28342 962005 16/01/2009 XML Ports do not import data that comes after a white space. Lars Lohndorf-Larsen Microsoft Dynamics UK Microsoft Customer Service and Support (CSS) EMEA These postings are provided "AS IS" with no warranties and confer no rights. You assume all risk for your use. Читать дальше
