emeadaxsupport: Corrupted data that may prevent you to post a purchase invoice
Источник: http://blogs.msdn.com/b/axsupport/ar...e-invoice.aspx
============== You may have a situation like the following ones:
It may happen that if AOS gets stopped suddenly or the client loses connection with the AOS, some records stay in specific tables that causes those issues. Here is a list of the SQL tables where the 'pending' record may exist. If the record is found in any of the following tables, the recommendation is to remove it (please, do it in a test environment before that a live one and having NO users working in the application). Then, check to see if you are able to properly invoice update the PO. PurchParmTable PurchParmLine PurchParmSubTable PurchParmSubLine PurchParmUpdate VendInvoiceInfoTable VendInvoiceInfoLine VendInvoiceInfoSubTable VendInvoiceInfoSubLine If you want to delete these record going through Forms, here another option: 1. Firstly checking PurchParm tables when looking History forms (Account Payable/ Inquiries/ History/ Purchase orders), and delete in (ckeck in record status is "Waiting"). 2. The next step is to check VendInvoiceInfo tables where you found the wrong records, You can access those records in the list page: Accounts payable module > Places > Pending Purchase Order Invoices. Here you can delete it as well. Note: pending invoice of your case will be in this list page. Hope it's helpful Kind regards Marialecia Guada Dynamics AX SCM Technical Lead Источник: http://blogs.msdn.com/b/axsupport/ar...e-invoice.aspx
![]() и отвал соединения при разноске будет приводить к порче бд |
Ну, с учетом отличного (от остальных) склада ума у разработчиков моногочисленных приобретенных "решений" - чему ж удивляться. Ну, проскочило каким-то образом в релиз - бывает, починят. Странно то, что публикуют в блоге вместо экстренного выпуска фикса. Надеюсь, починят к тому времени когда мы запускаться будем
-ТСЯ или -ТЬСЯ ? |
Я так понимаю, это не связано с "решениями". Это в 2009 появилось в стандарте как возможность вводить "предварительные" накладные и проводить сравнение заказ - отборочная - накладная. Но в итоге действительно выдает неожиданные результаты, даже если ничем из этого не пользоваться
Ivanhoe as is.. |
