axinthefield: Recording manual check in Dynamics AX
Источник: http://blogs.msdn.com/b/axinthefield...namics-ax.aspx
============== Recording manual check in Dynamics Ax 2009 Step 1: Setup bank management parameter Path: Dynamics Ax > Bank > Setup > Parameters ![]() Set field 'Allow checks for bank or ledger accounts' = True Note: This configuration enables manual check recording capabilities for CEU company in the system. Step 2: Create bank transaction type 'Check - Manual' Path: Dynamics Ax > Bank > Setup > Bank transaction type ![]() 'Ctrl + N' to create new record in the form Set field 'Bank transaction type' = 04 Set field 'Name' = Check - Manual' Click menu 'Save' Close form 'Bank transaction type' This setup completes the setup part. The transaction processing follows below from Step 3. Step 3: Process of recording manual check Path: Dynamics Ax > General Ledger > Journals > General journal Create a new journal line Select from list view 'Name' = GenJrn ![]() Click button 'Lines' ![]() Set field 'Account' = 600140 Set field 'Transaction text' = Payment Set field 'Debit' = 250.00 USD Set field 'Offset account type' = Bank Click tab 'Payment' ![]() Click button 'Transactions' ![]() Highlighted grid is the transaction with 'Payment reference' = 1201 This completes recording manual check process. Источник: http://blogs.msdn.com/b/axinthefield...namics-ax.aspx
