emeadaxsupport: After applying PSA hotfix problem with using “Manage Expenses” from Enterprise Portal
Источник: http://blogs.msdn.com/emeadaxsupport...se-portal.aspx
============== Lately we run into problem that after applying PSA hotfix in this case (PSA_HF_2009SP1_046) after creating a new expense report the page was blank, but expense report was still created. It happen that mentioned hotfix modifies AOT \ Web \ Web Files \ Static Files \ Proxies. The hotfix add following lines: /class:PSAProjBudgetTolerance /method:PSAProjBudgetTolerance.checkBudgetTolerance What would mean that in \wwwroot\wss\VirtualDirectories\
