axaptapedia: SourceCodeToHTMLPrinter
Источник: http://www.axaptapedia.com/SourceCodeToHTMLPrinter
============== Summary: Allows X++ Source Code to be converted and placed in the HTML Viewer where it can then be printed This is for those developers whom from time to time print their X++ source code to a printer. The standard functionality only prints in black and white. This small Module will allow you to print in color and will give the same look and feel as the CodeEditor. [[Image:SourceCodeToHTMLPrinter.jpg]] [[Media:SharedProject SourceCodeToHTMLPrinter.zip]] This Project has been developed for Microsoft Dynamics AX 2009 After the XPO SourceCodeToHTMLPrinter has been imported, the Method addIns_PrintCode should be inserted in the standard Class EditorScripts. The Method may be found in the Class SourceToHTML_Converter. Источник: http://www.axaptapedia.com/SourceCodeToHTMLPrinter
Тема | Ответов | |||
axaptapedia: Tutorial Password | 1 | |||
axcoder: PowerShell + Ax | 1 | |||
axaptapedia: Load Web Documents | 1 | |||
axcoder: AxPath is supported by axaptapedia | 0 |
