Старый 17.03.2008, 15:05   #1
axStart: Starting the code profiler from code
Источник: http://axstart.spaces.live.com/Blog/...C0A0!281.entry
The code profiler is a tool that tells you how many milliseconds a line of x++ code need to be executed. This tool is most of time used for analyses of defined scenario of your process. This code profiler runs the code in debug mode. So a process of 10 minutes can take 30 minutes when the code profiler is active.
So a large run of 1 hour, reproduce with the code profiler, makes no since. The trick is to profile small part of the process. We can do this with existing macros in AX.
#profileBegin('myrun')
//mycode
#profileEnd
Later on you have to calculate the sum and line totals for that run. Give this run a new name, otherwise you don’t get the line, method and class totals. I think this is a bug.
axStart: How to find line of code with a question mark in your AOT. Blog bot DAX Blogs 0 16.04.2008 22:05
axStart: Derive from Derived RunbaseBatch classes. Blog bot DAX Blogs 0 02.04.2008 20:05
axStart: Where is my code running Blog bot DAX Blogs 0 15.02.2008 16:40
Часовой пояс GMT +3, время: 23:42.
