Старый 24.07.2007, 16:30   #1
25,643 / 848 (80) +++++++
axaptafreak: Label for Query Range cannot be modified (still)
Источник: http://axaptafreak.blogspot.com/2007...cannot-be.html
In a query range (open AOT, Queries, any query, any range field), you can specify the property "Label". So you could display another label than the standard field label to be used in a query.
Unfortunately, if you put a label into the query range, Ax will give you an error "Field xxx does not exist", where "xxx" is the label you wanted to use.
This error existed in Axapta 3.0 and it still in exists in 4.0. (Maybe it also existed in 2.5 and back, so it could have a long bug history...)
As soon as I get the time to install my Ax 5.0 CTP application, I will check if the error is there as well and will tell it to the MS guys, so they can fix it for the next versions. Helmut Wimmer
Старый 25.07.2007, 09:46   #2
gl00mie is offline
gl00mie
3,684 / 5803 (201) ++++++++++
Получается, DAX5 уже на подходе?..
Старый 25.07.2007, 10:09   #3
belugin is offline
belugin
Аватар для belugin
4,622 / 2925 (107) +++++++++
Записей в блоге: 5
Да, идет CTP - правда, это единственный факт, который можно опубликовать не нарушая NDA
DynaMihamAX: Label import problem in Dynamics AX 4.0 Blog bot DAX Blogs 0 12.12.2008 13:05
axaptapedia: Packing date range values in queries Blog bot DAX Blogs 1 09.11.2007 13:10
axaptafreak: Label for query range cannot be modified in AX 5.0 Blog bot DAX Blogs 0 30.08.2007 16:50
Работа с Excel через COM и ошибка 0x800A03EC (Range.AutoFilter) gl00mie DAX: Программирование 15 30.03.2007 18:37
Часовой пояс GMT +3, время: 04:07.
