waldo: Upgrade to Business Central V17 (part 1) – The Workflow
Источник: https://dynamicsuser.net/nav/b/waldo...1-the-workflow
============== Recently, we have been going through upgrading our 65 apps to the newest release (v17). You might wonder: upgrade? Wasn’t this supposed to be seemless? Well, let me explain what we did, how we handle stuff internally – and then maybe it does make sense to you why we take the steps we took for upgrades like this. ![]() DevOps It seems I can’t stop talking about DevOps ;-). Well, it’s the one thing that “keeps us safe” regarding:
That’s where branching comes in (we just created a “v17prep” branch for every repo). Sure, we continued development, but once in a while, we basically just merged the master-version into the v17prep branch. Now, with our DevOps pipelines, we want to preserve code quality, and some of the tools we use for that, are the code analyzers that are provided by Microsoft. Basically: we don’t accept codecop-warnings. So, we try to keep the code as clean as possible, partly by complying with the CodeCops (most of them) that Microsoft comes up with. The pipelines basically fails from the moment there is a warning.. . I absolutely love this. It is a way to keep the code cleaner than we were able to with C/SIDE. And the developer is perfectly able to act on these failures, quickly and easily, because they get feedback from the pipelines. But – it comes with challenges as well:
And that’s totally ok! Really. This is one of the reasons why we have tests, right? To know whether an upgrade was successful? So, absolutely something the pipeline will help us with during an upgrade process! Yet another check, and definitely not less important: the “breaking change” check. The check that prevents us to allow any code that is breaking against a previous version of our app. It’s easy:
I’m not saying there are different ways to do this, like putting everything in one repository, one pipeline, .. (which also has its caveats), but having all apps in its own repository really works well for us:
I get why they did it: this is more of a “system library” than a “function library”, and basically the system app needs to be able to get to this, which shouldn’t rely on anything “functional”. So architecturally, I totally understand the change. But .. It’s breaking “pur sang”, and I really hope things like this will be done using obsoletions in stead of just “moving” .. . I’ll explain later what it involved to handle this issue for v17.Since we want to comply with all codecops, implement all new features with V17, I think I found a method that works for us to be able to work on it, spread over time. The flow So, DevOps (and SCM) is going to be the tool(s) that we will use to efficiently and safely tackle these problems. Step 1 Create branch I already mentioned this – all preparation can be done in a new branch. Just create a new branch from your stable branch (master?), in which you can do all your preparation jobs. When people are still adding features in the meantime, simply merge the branch again with the new commits from time to time – possibly adding new code that does not comply with the new version anymore – but that should easily be fixed.. . Step 2 Disable the (new) codecops that cause problems (warning or error) This step is in fact the time that you buy yourself. You make sure that you still comply with all rules you did not disable, but to start working on all rules that you don’t comply with yet, let’s first disable them, to later enable them one-by-one to have a clear focus when solving them. For us, this meant we added quite a bunch of codecops: All of which we meant to fix. Some more efficiently than others .. . I wanted to comply with most of them.Step 3 Make sure it compiles and publishes It wasn’t “just” codecops that we needed to worry about. As said, there was also a breaking change: the “Library – Variable Storage” codeunit that moved to its own app. Now, lots of our test-apps make use of that codeunit, so we needed to add a dependency in all our test-apps to be able to “just” run our tests against the v17 dev environments: Step 4 Enable codecop and fixUp until this point, it only took us about 30 minutes: creating a v17 container, branch, disable codecops .. all find/replace so we efficiently did the same for all apps .. and we were good to go: we had apps (and its test-app) that did NOT show any warning in the problems-window, and that was able to be published to a default V17 container where we were able to run tests. Time to get busy! To solve the codecops, we simply applied this subflow:
Step 5 Pullrequest From that moment, we started to pullrequest our apps to the master-branch, to perform our upgrade. Basically, I wanted to have all working pullrequest validation builds, before I started to approve them all to master branches. This was a very tricky thing to do ..well .. this was not possible to do, unfortunately. Simply said: all apps with dependencies to apps that used the “Library – Variable Storage” codeunit, simply failed, because the dependencies were not there yet in the previous apps, so it simply was not able to deploy them in the pipeline to a b17 container for: Checking breaking changes or installing the dependent apps. There is always a solution .. Since I don’t want to just abandon DevOps, this is the only way I saw possible:
The preparation took us about 3 days of work: we changed 1992 files of a total of 3804 files, spread over 65 apps. So you could say we touched 50% of the product in 3 days (now you see why I really wanted to have our breaking changes-check as well ;-)? The last step – the pullrequest – it took us an extra 2 days, which should have been just a matter of approving and fixing failing tests (only 5 tests out of 3305 failed after the conversion). Any tips on how to solve the codecops? Yes! But I’ll keep that for the next blogpost (this one is long enough already ).Источник: https://dynamicsuser.net/nav/b/waldo...1-the-workflow
