Старый 17.11.2012, 11:12   #1
vasantharivali: Using AOT Query Object in X++ Code
Источник: http://vasantharivali.wordpress.com/...ect-in-x-code/
Hi,
Here i posted the code to use the AOT Query Object in our X++ code.
Steps:
1) Create a AOT Query Object as your requirement.
2) Create a Job and paste the below code to check the Query Object.
static void ExecuteAOTQuery(Args _args)
QueryRun queryRun;
Counter totalRecords;
queryRun = new QueryRun(queryStr(CreatedAOTQueryName));
if (queryRun.prompt())
while (queryRun.next())
totalRecords++;
info(strFmt(“Total Records : %1”, totalRecords));
vasantharivali: Dynamic Query Using Aggregative Functions and Joins Blog bot DAX Blogs 0 17.11.2012 11:12
xplusplus: Dynamics AX Application Object Tree (AOT) Blog bot DAX Blogs 0 25.11.2010 18:11
emeadaxsupport: Renaming an AOT object in Dynamics AX 2009 that is under source control with Team Foundation Server Blog bot DAX Blogs 0 06.10.2009 02:05
SysDictCoder: Changing properties of AOT objects in code Blog bot DAX Blogs 0 04.05.2009 20:05
Вопрос про Demand Planner slava09 DAX: Функционал 4 25.09.2006 11:43
Часовой пояс GMT +3, время: 16:48.
