Старый 31.08.2009, 12:05   #1
lcash: Using workflow on the R2 demo VM
Источник: http://blogs.msdn.com/lcash/archive/...2-demo-vm.aspx
So I had a question that prompted me to remind people about the setup for Workflow. The workflow in AX runs under the Windows Workflow foundation which is hosted, in AX2009, under IIS. This engine and the AOS communicate together to execute the workflow.
So if you have running the demos VMs and the workflows are in the queue but you they are not running for you then make sure you have the Webserver running on the demo VM.
To do this click Start\Control Panel\Administrative Tools\Services. Scroll down to “World Wide Web Publishing Service” and start this service.
Cheers
Lachlan
Original post at http://blogs.msdn.com/lcash
lcash: Microsoft Demo Showcase Suite Release at WPC2009 Blog bot DAX Blogs 0 30.07.2009 08:06
lcash: Moving the AX App and DB onto a new VM Blog bot DAX Blogs 0 29.07.2009 12:05
lcash: Having trouble starting the AOS on the Demo VM ? Blog bot DAX Blogs 0 22.07.2009 02:06
lcash: Using document handling to add image in Demo VM Blog bot DAX Blogs 0 21.07.2009 10:05
Часовой пояс GMT +3, время: 17:44.
