Старый 20.04.2017, 21:11   #1
25,643 / 848 (80) +++++++
gustafwesterlund: Some dashboards are more equal than other
Источник: http://gustafwesterlund.blogspot.com...qual-than.html
Typically you are not allowed to remove components from the system layer in Dynamics 365/CRM
Is this dashboard more pig than horse?but for some reason this does not apply to dashboards in some earlier versions of Dynamics CRM. It seems this bug has recently been fixed but if you have a version of CRM where this was possible or have been upgraded from this version, you might be missing it. I just tried this in the Online version
8.2.0.798 and in this version it is not possible to delete dashboards but I have managed to in earlier versions.
My friend Jerry Weinstock has blogged about this as well.
One particular dashboard that the system is in dire need of for its mobile features is the "Sales Dashboard" as this is the default dashboard for the mobile and tablet clients. This cannot be changed although the default dashboard can be changed within the mobile client by the user after it has been started. See MSDN for more info in this.
In case you do manage to delete it or it has been deleted, Power Objects blog have described how to restore dashboards from instance with this dashboard in it. In short, create an unmanaged solution in that other instance containing the "Sales Dashboard" and then export and import the solution into the instance missing it.
Before closing the window showing the results, open the log of the import and get the guid of the dashboard and then use the url of another dashboard to insert the GUID into the url to get to the "Sales Dashboard" and change it's name and/or the label of the the tab to what it typically is in case it doesn't show up directly.
In case you do not have one, here is a link to an unmanaged solution file (version 8.0) containing just the sales dashboard. SalesDashboard_1_0_0_0_target_CRM_8.0.zip
Gustaf Westerlund
MVP, Founder and CTO at CRM-konsulterna AB
www.crmkonsulterna.se
gustafwesterlund: Extending Max amount of components on dashboards only for onprem Blog bot Dynamics CRM: Blogs 0 24.10.2016 23:11
gustafwesterlund: 10 Tips for Success designing solutions for Dynamics CRM Blog bot Dynamics CRM: Blogs 0 03.12.2015 17:11
gustafwesterlund: More on the insecurity of cloud data Blog bot Dynamics CRM: Blogs 0 29.01.2013 19:11
gustafwesterlund: More swedish CRM blogger Blog bot Dynamics CRM: Blogs 0 01.09.2012 12:15
gustafwesterlund: Unable to upgrade CRM 4.0 database more than once Blog bot Dynamics CRM: Blogs 0 20.01.2012 17:11
Часовой пояс GMT +3, время: 15:36.
