Старый 23.09.2014, 01:11   #1
goshoom: Aggregation of expressions in SSRS
Источник: http://dev.goshoom.net/en/2014/09/ag...sions-in-ssrs/
Imagine you have an SSRS report with a tablix, which contains a calculated field. For example, there is a date field (from a data set) and a calculated field showing the difference between the given date and the current date:
The Diff field is calculated by the following expression:
=DateDiff("d", Fields!GivenDate.Value, Today)
Now we want to add a field showing the sum of differences. First off all, add a new row below the Details group (i.e. the row with individual dates) using Insert Row > Outside Group – Below.
The only question is how to implement the expression of Total diff. You probably know how to summarize values of a dataset field – by =SUM(Fields!SomeField.Value). But we’re not limited to fields, we can use almost any expression there. Therefore we simply put the expression calculating date difference to the SUM function:
=SUM(DateDiff("d", Fields!AccountingDate.Value, Today))
Indeed, the total difference is calculated as expected.
kamalblogs: SSRS Tip: Printing Row headers in every page – Dynamics Ax 2012 Blog bot DAX Blogs 0 23.09.2013 16:12
dax-lessons: Cheque customizations in Dynamics AX 2012 – SSRS, expressions in SSRS reports Blog bot DAX Blogs 0 24.11.2011 23:11
saveenr: Dynamics AX & SSRS Learning Roadmap: Part 4 - Adding Headers and Footers and an Introduction to Expressions Blog bot DAX Blogs 0 24.05.2010 15:05
Часовой пояс GMT +3, время: 02:14.
