Старый 19.02.2014, 01:13   #1
axepclipboard: Compare in TFS history on an item with a large history does not work
Источник: http://feedproxy.google.com/~r/AxEpC...3/1Ko8Vszrm94/
After developing on our product for a long time, we are experiencing some problems on objects with a large history in TFS, comparing 2 versions in the rich client does not work anymore. We can select our 2 versions and try to compare them but nothing will happen. So what to do if you really [...]
The post Compare in TFS history on an item with a large history does not work appeared first on Ax EP Clipboard.
fed: Net requirements update in MRP Module and Working Set of MRP Blog bot DAX Blogs 14 08.05.2012 13:09
emeadaxsupport: Purchase Requisition Workflow in Dynamics AX 2009 fails with Stopped (error): Work item could not be created. Insufficient rights for user Blog bot DAX Blogs 0 18.11.2010 21:12
dynamicsaxtraining: Item setup: Inventory dimension group Blog bot DAX Blogs 1 05.10.2010 15:35
Вопрос про Demand Planner slava09 DAX: Функционал 4 25.09.2006 11:43
Часовой пояс GMT +3, время: 07:06.
