Старый 06.07.2010, 23:05   #1
25,644 / 848 (80) +++++++
kamalblogs: Adding a breakpoint through code in Dynamics Ax
Источник: http://kamalblogs.wordpress.com/2010...n-dynamics-ax/
Every time I see a warning or error, the default place where i place my debugger was at “\Class\Info\add”. I was really not happy of going each time to the same class to place a breakpoint. This week i got rid of it finally
What I did was develop a small piece of code that will automatically add a breakpoint and called this piece of code from the internal development toolbar that we have. The internal development toolbar is something like Tabax.  You can also do the same and integrate with your own toolbar/ Tabax / Ax Assist.
static void  addBreakPoint(Args _args)
	    container bpCon;
	    int       vers, i;
	    //Get the breakpoint
	    bpcon = infolog.breakpoint();
	   //Version just for reference not really needed
	    vers = conpeek(bpCon, i); i++;
	    //set the breakpoint
	    bpCon += [@"\Classes\Info\add"];
	    bpCon += [1];
	    bpCon += [true];
	    infolog.breakpoint(bpCon);
Refer to the article below if you want to know or create toolbar for Ax. http://kamalblogs.wordpress.com/2007...namics-ax-4-0/
kamalblogs: Adding custom images for Treenode in Dynamics Ax Blog bot DAX Blogs 0 25.01.2010 17:05
emeadaxsupport: Debugging non-interactive X++ code in Dynamics AX 2009 when running on Windows Server 2008 Blog bot DAX Blogs 0 23.09.2009 13:05
Часовой пояс GMT +3, время: 00:36.
