Старый 18.07.2012, 19:11   #1
25,644 / 848 (80) +++++++
emeadaxsupport: Slow POS when no internet connectivity
Источник: http://blogs.msdn.com/b/axsupport/ar...nectivity.aspx
Description:
When starting the POS it takes several minutes to launch. We traced this behavior with Netmon and saw that POS called unsuccessful VeriSign and Akamai. This caused a delay
in the POS startup.
Cause:
It is standard security behavior for Authenticode signed .NET applications to try and verify the certificate
authority. In the case of non-Internet connected machines this could cause this
behavior as it will time out trying to connect to the server.
Solutions:
1. First solution is to disable the publishers certificate revocation, but this solution disables it for the whole computer.
Internet Explorer
> Tools > Advanced > Check for publishers certificate revocation.
2. Second solution is to modify the Pos.Exe.Config file found in the POS directory,by adding the following XML string
Note:
The generatePublisherEvidence was introduced in .Net framwork 2.0. POS is compiled in :net framework 3.5 and therefore the key works there as well.
http://support.microsoft.com/kb/936707/en-us?fr=1
Author: Kim Truelsen
Date: 18/7-2012
emeadaxsupport: POS printer is not recognized by POS (AX2009 & AX2012) Blog bot DAX Blogs 0 17.07.2012 18:11
emeadaxsupport: AX2012 POS: Adding a new line is slow Blog bot DAX Blogs 0 21.04.2012 13:12
emeadaxsupport: Retail: How to access multiple POS from one machine Blog bot DAX Blogs 0 26.08.2011 21:13
emeadaxsupport: Buttons in the POS layout are not all localized. Blog bot DAX Blogs 0 25.08.2011 19:11
Часовой пояс GMT +3, время: 21:10.
