kamalblogs: Quick Excel report – Dynamics Ax 2009
Источник: http://kamalblogs.wordpress.com/2011...amics-ax-2009/
============== Excel is the most convenient software to examine changes in data. Specially when you have made them code and wanted it to be tracked. That’s is one of the many reasons why excel tops to be the most used software in the world. This article in detail will tell you how to create an ad hoc excel sheet just in case you wanted to show data changes, compile information from different tables etc. Create a similar code for your need. [Follow inline comments to understand the code] X++: static void JobExportToExcel(Args _args) { SalesLine salesLine, oldSalesLine; str text; TextIO io; #WinAPI ; //Column header for the excel. The header fields and the data field must match //in number and order //You can use anything as a delimiter but # is convenient as this rarely appears //as data (other choices ~, |) text = 'Order # Customer # Item # Lot id # New tax group # Old tax group \n'; select * from salesLine where salesLine.TaxItemGroup == 'GST' || salesLine.TaxItemGroup == 'Free'; while (salesLine) { //save this incase you wanted to show the old value oldSalesLine = salesLine.orig(); if (salesLine.TaxItemGroup == 'GST') { salesLine.TaxItemGroup = 'CAPITAL'; } else { salesLine.TaxItemGroup = 'Free'; } //append the text text += strfmt('%1 # %2 # %3 # %4 # %5 # %6 \n', salesLine.SalesId, salesLine.CustAccount, salesLine.ItemId, salesLine.InventTransId, salesLine.TaxItemGroup, oldSalesLine.TaxItemGroup); //do it after the update text otherwise you loose the orig salesLine.update(); next salesLine; } //So far no excel <img src="http://s2.wp.com/wp-includes/images/smilies/icon_smile.gif?m=1268811511g" alt=":-)" class="wp-smiley"> ...that comes later io = new TextIO(WinAPI::getFolderPath(#CSIDL_DESKTOPDIRECTORY) + '\\exportToExcel.txt', 'w'); io.write(text); } step 1. Create a delimited text IO file through a job as shown above step 2. Open Excel (Don’t try rightclick open with). setp 3. Click Open file -> Select “ALL files” in the export dialog step 4: select the textIO file that was recently given step 5: Specify delimited in the dialog and enter the delimiter (# in this case) step 6. Click finish your data is in. ![]() ![]() Источник: http://kamalblogs.wordpress.com/2011...amics-ax-2009/
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. Последний раз редактировалось Poleax; 10.05.2011 в 08:48. |
Опции просмотра | |
